I have changed stock Anet A8 board (Anet v1.5) to new SKR 1.4 with TMC2209. Then I found out these lines on the walls, i don't know how to determine it. Previously this wasn't so visible, but now it bothers pretty much.
Benchy
XYZ Cube
Looks like an over/under extrusion. This can be fixed by:
  • decreasing/increasing your extrusion multiplier (flow)
Flow parameter in Cura
  • lowering your print temperature
  • checking the diameter of your filament. Do you use the correct diameter?
Diameter option of material in Cura
| improve this answer | |
  • $\begingroup$ I tried different values of Flow i.e. 90,95,100% - I think 95 works the best. I use the same printing temperature as you and the same filament diameter. Also i calibrated e-steps. I have been trying to solve this problem for several days and I have no idea. $\endgroup$ – blitzpl12 Apr 20 at 20:47
