I've got a Renkforce RF1000 which should be a good 3D printer. I got it second-hand for my birthday one year ago. I've got no way of contacting the old owner.
I spend a good amount of hours fine-tuning the slicer settings last year but at best got mediocre prints. Between September and a week ago I lived somewhere else and didn't touch my printer.
Now here's what I don't know:
  • I don't know what parts are replaced
  • I don't know what my nozzle size is
  • I don't know if the limit switches are calibrated correctly
    • Though I think they are. This doesn't seem to be a problem. I did re-calibrate the Z-axis
Here are some important details:
  • I use 3 mm Renkforce PLA filament which I print at 190 °C on a bed heated at 60 °C. The PLA is over one year old now.
  • There's a fan on the motor on top that isn't connected to anything.
Here are some of the problems I've got:
  • I've had multiple prints failing due to the extruder not working properly. The motor keeps on spinning but the "feed knurl" remains stationary
  • I can't seem to get the right extraction settings
  • I can't seem to get my prints to consistently stick. It tends to work when I heat the bed to 60 °C and use glue and get lucky.
Feel free to give any thoughts you've got. These are the most important questions I've got:
  1. Should I replace the nozzle with this one so that I know what nozzle I've got and so I'm sure this isn't a problem?
  2. Should I replace the filament with new 1.75 mm PLA? If so, why?
  3. How do I fix the extruder?
  • I tried getting the "feed knurl" off but can't seem to do this easily. I've got some super glue I could try to put in there but something's telling me this might be a very bad idea...
  1. Is the unconnected fan important and if so: what do I do with it? There's no remaining wire to connect it to.
  2. How tight should the 4 screws that hold the filament between the extruder and the rolling disk be?
For now, these are all hardware problems. I can post my Slic3r settings too but I believe the hardware should be fixed before going into slicer settings.
Here are some pictures showing the problems:
Top image one
This is the extruder. The feeding mechanism can be seen in front. It shows the "feed knurl" of which the inside spins while the outside remains stationary (question 3). Next to it are 4 screws which determine how tight the filament is held against the extruder (question 5). On the back it shows a black fan, this got placed by the previous owner but isn't connected (question 4).
Image unconnected fan with unscrewed extruder
This image shows the unconnected fan (question 4) to the right. Behind it is the motor that's connected to the extruder. The motor works but the extruder doesn't spin with it. The extruder has a little black hole on top.
Front view extruder
This shows the extruder from the front. The inner layer spins, the outer layer doesn't (question 3)
Failed print example
These are some of the prints when the extruder was still working.
Nozzle and print bed
Nozzle and print bed (question 1)
    $\begingroup$ If the stepper spins, but not the extruder gear ("feed knurl"), you need to tighten the grub screw. $\endgroup$
    Apr 23, 2020 at 22:24
    $\begingroup$ That "black hole" on top is the grub screw ("threaded pin" in the Chinglish instructions). It can be tightened with a hex key to lock the drive gear to the motor's shaft. $\endgroup$ Apr 24, 2020 at 7:36
    $\begingroup$ Be careful with Z calibration: just like the other ones, it's better if you just calculate the theoretical value and stick to it. Also, I use 5 years old 3 mm PLA (after drying it in a silica filled box) with no problems, it only tends to snap if left stretched for a while, so I remove it from the extruder when not in use $\endgroup$
    – FarO
    Apr 24, 2020 at 9:08
    $\begingroup$ Nozzles are consumables. If you don't know the age (in "spools") of the old one, don't even ask and replace it. $\endgroup$
    – FarO
    Apr 24, 2020 at 9:10
    $\begingroup$ it can, but it also can be a bad filament path with a sharp bend. $\endgroup$
    Apr 24, 2020 at 10:18
It appears the default nozzle size is 0.3 mm. The linked nozzle is a direct replacement.
The "feed knurl", usually called the extruder gear is attached to the stepper shaft using a fine grub screw ("threaded pin" is a bad choice of words...). The black hole you mention is the hole of the screw (it should be in there, usually an allen key or flat screwdriver should be used). Position it so that the screw is tightened against the flat spot on the stepper shaft.
If the PLA has been open for a year and not stored properly it could have taken up moisture, I would buy a new spool (3.0 mm) of filament, not 1.75 mm.
The fan doesn't look as if this is a default fan, this fan is mounted onto cooling fins probably put there by the previous owner to cool the extruder stepper. Maybe the printer has been enclosed and used to print ABS at elevated temperatures. For Printing PLA cooling the extruder stepper would not be necessary as it doesn't require an elevated print temperature.
The 4 screws need to be tight enough for the extruder gear to leave indentations on the filament, but not too deep.
  • $\begingroup$ Thank you! Where'd you find the default nozzle size? The manual on the SD card says the nozzle diameter is 0.5 mm. Would the wrong nozzle size in the slicer show significant differences in the results? $\endgroup$
    – Stefan
    Apr 24, 2020 at 8:49
    $\begingroup$ @Stefan yes - the nozzle dameter dictates directly how the print is configured. 0.5 mm in the setting with a 0.3 mm nozzle gets you a different print than having the same settings, your prints should be lacking stability. $\endgroup$
    Apr 24, 2020 at 10:22
    $\begingroup$ You'll see the difference when printing. Make that a new question then. :-) $\endgroup$
    Apr 24, 2020 at 10:28
That is not really necessary. The exact nozzle size does not really matter.
No, there's no reason to do that. Going from 3 mm to 1.75 mm filament usually requires replacing the entire extruder.
Tighten the grub screw (the "black hole") with a hex key.
The fan appears to be cooling the stepper motor. This shouldn't really be necessary, the stepper should be fine without any additional cooling. People tend to "upgrade" their printers by adding unnecessary bells and whistles so it is possible the original owner added this fan just because they wanted to, and not because it is necessary.
Tight enough that the extruder grips the filament and is able to extrude it consistently. If it is too tight it might deform the filament too much which could cause printing problems but it should be obvious if this is the case. There is a wide margin here so don't worry about this too much.
    $\begingroup$ If the stepper fan is not used, the fan should be better removed to improve cooling $\endgroup$
    – FarO
