Just got a Creality Ender 3 yesterday. Set it up and ran the dog test print. Photo below.
I used the sample filament that came with the machine. I'm not 100 % what kind it is, but assuming it is 1.75 mm PLA.
No matter what temperature I set the end and bed, when I launched the print, it would change to 200 °C hotend, 45 °C bed. Is that because the two temperatures are set within the gcode file? Do I need to set a higher nozzle temperature? And to do so, will I have to alter the G-code file?
Does the head need cleaned? I did try some blue ABS I bought, and didn't work, so I switched it to the sample filament. There was still some blue ABS in it, but seemed to be gone after a few seconds after the extrusion turned pure white. But might there still be some ABS clogging or slowing the filament?
EDIT: When I ran the test file with ABS, the material didn't adhere to the bed or itself, just created a jumbled bird's nest of spirals. Then I found something online that I needed to use the temperatures on the ABS spool. I set the temperature to 245C nozzle, 100C bed. But as soon as I ran the print, the nozzle went to 200 and the bed 45.
Is the motor that moves the filament moving too slow?
Is the head moving too fast?
Should I use a glass bed?
