A few months ago I got an Ender 5 printer. After a few successful prints with only PLA, I started getting a lot of issues. The last time I came back after an hour and there was just a bird's nest around the nozzle.
I cleaned up all the PLA I could visibly see around the nozzle and the inside as much as I can tell. I decided to replace the nozzle, but when I tried to remove it, it was stuck. All the wrenches I have couldn't hold it, and now it's stripped pretty smooth.
What options are left? Was there PLA stuck inside the hot bed that's holding the nozzle? I heated it to printing levels to soften it but no luck.
  • $\begingroup$ Pics? You probably need to replace the block but it's not expensive or a big undertaking. $\endgroup$ – R.. GitHub STOP HELPING ICE May 17 '20 at 15:26
    $\begingroup$ Try a pair of vise grip pliers, that should work. But as suggested, replace heater block and nozzle, see this answer. $\endgroup$ – 0scar May 17 '20 at 20:47
