Sometimes my Extruder will start spinning pointlessly fast and long.
Youtube Video showing the problem
This Issue only happens:
- When printer has finished a Layer and moved up to the next (right after the Z axis has moved)
- Not on all, but only on some layers of a print.
Typically it will be more towards the middle of a print, and it will happen on several (maybe 10, 20, or a lot more) consecutive layers
My regular Setup/Stack:
- PrusaSlicer-2.0.0+win64-201905201652
- Octoprint (Version 1.4.0)
- Tevo Tornado (with Mamorubot print-platform)
I have tried to test whether the source of the problem could be Octoprint or the slicer/gcode.
Octoprint:
The problem persists, when i print directly from SD
slicer/gcode:
Here is some gcode, one of a layer change where the problem did occur and one where it was fine:
Problem occured here:
G1 X167.854 Y170.305 E209.95401
G1 X167.851 Y132.289 E210.24063
;BEFORE_LAYER_CHANGE
G92 E0.0
;3.95
G1 Z3.950 F7800.000
;AFTER_LAYER_CHANGE
;3.95
G1 X168.141 Y131.859
G1 F3600
G1 X129.532 Y131.858 E211.24663
G1 X128.945 Y131.592 E211.26340
G1 X128.419 Y131.004 E211.28396
No Problem occured here:
G1 X168.288 Y170.558 E474.06508
G1 X168.224 Y170.259 E474.06950
G1 X168.213 Y131.857 E474.62495
G92 E0.0
;9.8
G1 Z9.800 F7800.000
;AFTER_LAYER_CHANGE
;9.8
G1 X168.559 Y131.441
G1 F3600
G1 X129.622 Y131.440 E475.63947
G1 X129.198 Y131.248 E475.65161
G1 X128.776 Y130.777 E475.66807
I cannot see any problem with the gcode.
Now I am at my wits' end - what could be the source of the problem, and how to I proceed to debug it?
G92 E0.0
on layer change coming from? Because it looks like you're settingE
to 0, but then after moving in the X/Y, your first move has to spin it all the way to 470-something. Are you sure you're not seeing this on every layer change? $\endgroup$
