What could be the causes of a consistent over-extrusion? I know about these:
  1. steps/mm of extruder motor set too high
  2. larger filament diameter
  3. slicer setting: filament diameter - setting it lower makes the printer extrude more filament
  4. slicer setting: extrusion multiplier - setting it higher makes the printer extrude more filament
  5. unlikely but possible bug in slicer or in printer firmware
  6. other: low/high tempereture, too much/little tension on the extruder gears, wrong nozzle fitted,...
Now to my problem. I had to replace the entire hotend assembly on my Prusa i3 MK2,5. Before that, there was no issue. After the replacement and after noticing the issue, I followed the list above. I recalibrated the extruder and in fact I had to increase the steps/mm to match the extruded length.
I have printed with different filaments and the issue is still present. Also I checked the diameter of all the filaments which are quite consistent (1,75 +-0,3 measured, 1,75 +- 0,5 given by the manufacturer). All of them were the same brand.
I also checked slicer settings and the default values that I used before were still there.
Slicer and firmware versions are the same as before the issue started occuring.
I use the same print settings as before and have checked the extruder gears tensioner multiple times over. The nozzle came with the hotend and according to the E3D dots it is in fact the default 0,4 mm nozzle. However, I cannot check the real diameter.
I know I can solve this issue by altering the steps/mm or extrusion multiplier because the over-extrusion is consistent. I want to know if there is something I am missing that could cause this.
Thank you for your valuable time and suggestions.
Edit: Image 1
Image 2
  • $\begingroup$ Did you ever find a solution to this? $\endgroup$ Jul 6, 2020 at 22:23
  • $\begingroup$ No. I have once again tried recalibrating the extruder, this time I decreased steps/mm. As you have said, it is minor overextrusion so I might just roll with it. $\endgroup$ Jul 8, 2020 at 9:11
This is almost surely the source of your problem:
There is no plausible physical reason for extruder steps/mm to change due to replacement of the hotend. Steps/mm is purely a function of stepper motor steps per rotation and extruder gear radius. Set it back to its original value.
If the extruded length is not matching what it should, you have a problem with blockage/flow rate in the hotend restricting advance of the filament and causing the extruder gear to grind without moving it, or the motor to skip steps. Adjusting steps/mm to "compensate" will not fix this; it will just grind/skip more. Instead go back to the beginning, with steps/mm set correctly to the original value, and start looking for the cause of your hotend problem.
12
  • $\begingroup$ I have disassembled and reassemled the assembly, recalibrated the extruder and still nothing. Also, your answer does not make any sense when talking about over-extrusion (it would make a lot of sense when talking about under-extrusion). A blockage in the filament path cannot increase the flow of the plastic consistently. It can do it repeatedly: pressure builds up in the fillament because of a blockage, when the pressure is large enough, the filament gets released, therefore momentarily increasing the flow of the material. But that is not what I am experiencing. My over-extrusion is consistent $\endgroup$ Jun 5, 2020 at 15:59
  • $\begingroup$ @MStarha: The overextrusion happened even before you made any adjustment to the steps-per-mm? You said you increased the steps/mm which absolutely would cause overextrusion. $\endgroup$ Jun 5, 2020 at 16:03
  • $\begingroup$ Yes, it happened before the first extruder adjustment and after the hotend change. That's the problem, it was over-extruding even when in fact the extruded length was shorter than requested. $\endgroup$ Jun 5, 2020 at 19:52
  • $\begingroup$ What you're describing is physically impossible (less length at same diameter but more volume). Are you sure what you're seeing is overextrusion? Can you provide some pics? $\endgroup$ Jun 5, 2020 at 20:41
  • $\begingroup$ Added pictures to the original post. I know it is not logical, thats why I am here. Cannot figure it out myself. The over-extrusion is subtle, but it is there. As long as it is there, I cant trust the dimensional accuracy. $\endgroup$ Jun 6, 2020 at 18:54
