Printing supports, either complete, or partially from PVA have not always resulted in successful prints according to my experience with the filament (used in a dual extruder Ultimaker 3 extended). But, when it works well, the surface finish is perfect as there is no gap between the PVA and PLA.
From my experience with PVA, I conclude it is prone to clog, the filament is very hygroscopic, resulting in popping sounds when printing if too moist which most probably also impacts on clogging. The clogs lead to failed support structures as the extruder grinds through the filament and as such failed prints.
I was wondering if PETG can be used for supports or for the interface layer of supports for printing supports for PLA prints? For example:
This is a sliced view of a print in line color (left or top on small screens) and material color (right or bottom on small screens); black PLA and cream colored PETG. This print contains a larger gap that needs support. Can you make the support from PETG, either the support as a whole or just the top interface.
- How does PLA-PETG or PETG-PLA bond or stick considering the 2 different print temperatures?
- What are the concerns using a single nozzle?
