I have a repair part that I need to print with ABS and I know that I have warping problems with ABS.
I'm now trying to mitigate this by printing a circle around my object and use more brim. You can consider this as a manually designed skirt, but I want the brim to be on both sides of the skirt.
However, when slicing the repair part with the ring, I get brim only outside the "skirt", not inside of it. How would I get brim also in the area marked here?
