I've got this second hand printer today, but, when I want to start printing, the temperature sets to cooling mode and the print never starts.
CR 10 S Pro display says: Cool...
This is what I've done so far...
  • Upgraded firmware for the board and screen to Tiny Machines latest version.
  • Check temperature manual for bed and nozzle and works fine
  • Level the bed
  • I used Cura with several profiles, even with an Ender 3 profile from my other machine to see if the slicer is the one giving issues
On other G-codes that i tried, the message changes to in the pause and completing percentage is set to 218 %...
Any ideas?
  • $\begingroup$ Ok, to make things weirder, i try printing using pronterface, so i could get the logs, and its working with the same gcode, i used 2 different sd cards, so could it be the sd card reader? $\endgroup$
    – frenciaj
    Jul 2 '20 at 0:50
  • $\begingroup$ When i use the sd card, still connected to pronterface, it fails sgain and the only error is a warning about homing division something $\endgroup$
    – frenciaj
    Jul 2 '20 at 1:25
  • $\begingroup$ sounds like in flashing your firmware there was some error and you need to re-flash it properly... did you install a bootloader first? $\endgroup$
    Jul 2 '20 at 6:27
  • $\begingroup$ So you check gcode in notepad++. Try find commands to set cooling in code. Maybe it is start gcode on cura or one of value in settings $\endgroup$
    – Юрий
    Jul 2 '20 at 6:32
  • $\begingroup$ @trish The cr10s pro doesnt need a bootloader, i followed the directions from tinymachines and did it twice $\endgroup$
    – frenciaj
    Jul 2 '20 at 11:46
File name is too long, I had the same issue, shortened the file name and now printing perfect
    $\begingroup$ Do you know what the maximum number of characters allowed is? $\endgroup$
    Jan 13 at 11:04
