I am having a tough time to understand scaling out and in STD files loaded into the Creality Slicer 1.2.3. For instance an STL like this:
facet normal -nan -nan -nan
outer loop
vertex -0.0515186 0.0260341 0.0015
vertex -0.0514094 0.0260341 0.0015
vertex -0.0516411 0.0260341 0.00172995
endloop
endfacet
This STL is super small, considering that the default unit for STL is a millimetre, but when I open it in the Creality Slicer it shows me that the model is much larger.
I assume there is some scaling mechanism in the slicer (also for large STL). Do you know how it works? It seems to me that there are some rules. For example, if the max length of the facet is < 0.05, the slicer changes the unit to meters(?).
