I am using two resin printers based on the ChiTu software (Creality LD-002R and SainSmart Kumitsu KL9), and the former uses ChiTu 1.6.2, while the latter came with 1.6.1. I believe both will work just fine with the latest version, but it occurs to me that having separate copies of the software may be a good idea to keep configurations separate as well: Creality's version of the software came pre-configured (and the settings are undocumented!), while the SainSmart manual documents the software settings.
I don't want to go back-and forth between two sets of settings manually — the secret recipe approach has poor UX and time's a wastin'. I am wondering if there is any concern with installing multiple copies of ChiTu. And if anyone has a smarter way to accomplish the same (printer profiles? INI files?), I am all ears.
Running multiple versions of the same software did not sit well with the software person in me, so I dug a little deeper.
ChiTu has a "settings" button to the right side, and under that section it is possible to configure different, separate printer profiles. That may take care of the differences if properly configured, unfortunately only some printer profiles are pre-loaded. ChiTu 1.6.4 includes the Creality LD-002R profile, while the very recent Kumitsu KL9 is not predefined (yet), but the manual comes with a screenshot of the parameters just as they need to be entered.
