I was watching a friend's Prusa run the bed-probe routine and I realized how pathetically slow mine is and takes forever. I want to speed it up.
What parameters in Marlin's Configuration.h
do I modify? Also, it seems to retract for the second "accurate" probe by like 10 mm which could be reduced by 8 mm or so. Where is that one? I looked through but can't be sure. Also, could I just change the feedrate in the pre-script?
#define DEFAULT_MAX_FEEDRATE { 300, 300, 8, 50 } // was { 400, 400, 8, 50 }
