I have a Wanhao Duplicator i3 Plus Mk2. Its auto-leveling never worked properly since I bought it a year or two ago. I decided to upgrade the firmware to try and solve this problem. Unfortunately, I did not know I had a Mk2 when I started this process (I'm a photographer, it is only a Mk2 when it says so on the Camera housing which is seemingly not the case here, you needed to be fortunate to know it is a Mk2 if it has a Z probe). As such, I uploaded the wrong motherboard and LCD firmware (for i3 Plus not i3 Plus Mk2). When I switched on and tried to level, it started driving the nozzle into the bed which in retrospect is to be expected as the firmware is looking for a switch, not a probe. Once I realised what the problem was, I uploaded the Mk2 firmware but it seems uploading the non-Mk2 firmware has confused something somewhere so I can't get it to even be a printer anymore. The LCD is all mixed up with menus over one another and the printer does not react to anything. I tried to format the LCD with the image and procedure on Wanhao's site but this merely seems to exacerbate the problem.
Can anyone please guide me on how to start fresh and get the printer and LCD firmware restored so at least I have something resembling a printer again. The Wanhao customer support has been all but helpful and I've abandoned that channel as they simply email me the same firmware I already downloaded and used to get into this mess.
M502
andM500
after the flash to the printer to get the values from the firmware and overwrite the current stuff in the EEPROM. $\endgroup$ – 0scar♦ Sep 15 '20 at 13:55
