My 3D printer was working perfectly, but one day I put it inside an acrylic box and put it to work, that was not a good idea, because the Z axis grabbed the box, after that, the Z axis started to rotate strange, I even tried to change the wires between the motors and the drivers, but it didn't work.
I have a suspicion that the drive must have a safety criterion, so when something strange happens it stops sending the necessary current for the stepper to run, if it is possible. Does someone have any tips on how to make it work correctly again? Remembering that the motor that is working in a strange way is the motor on the right side of the Z axis, the motor on the left side looks normal. Below I will leave a video showing how the printer is working, like, if it moves just a little bit with the Z axis, it looks like it works normally, but if I move it a little more, then it starts to get weird.
On this printer, I used a AtMega Arduino, with RAMPS 1.4 shield, with A4988 drivers, "NEMA 17" steppers and and I'm using the Repetier-host program to control the printer.
Video:
