I'm building a weather-proof enclosure for some electronics. It's expected to stay exposed outside all the time so I'm worried about its resistance:
  • What would recommend me for 3D filament? I was thinking about ApolloX ASA but I don't have an enclosure.
  • What post-processing should I go with without being overkill? I was thinking about:
    • Resin coating (was thinking about XTC-3D)
    • Filler/Primer spray
    • UV-resistant spray paint
    • Water-proofing spray
  • The enclosure have some moving parts exposed, how do I make the junction between them water-tight?
    $\begingroup$ What is the problem with the moving parts? if they are inside, why do you need to make them watertight? $\endgroup$ – FarO Nov 3 '20 at 14:37
  • $\begingroup$ I will have some exposed junction where water could enter and drip on the motors and electronics. I re-phrased it in the post @FarO $\endgroup$ – geauser Nov 3 '20 at 16:41
There are already some questions about the choice of filaments for outdoor use:
Which is more durable to sunlight/weather - PLA, ABS or PETG
3d printing for outdoor use: what types of filament are most weather resistant?
PLA use outdoors?
It may very well be that if you print in PETG you won't need any postprocessing.
If you still want to, you could try to paint or spray the outside with some bitumen spray for car underbody.
I think that the only part which actually needs postprocessing is the spot with exposed moving parts.
It's difficult or impossible to find a solution without having an idea of what we are talking about when you say "some moving parts exposed", but in general this is solved first of all by adapting the design so that water wont' be an issue: rain should flow away without getting inside, and spatwater should be reduced so that it will evaporate when rain stops.
If you only have an exposed pin for rotating parts which are inside, you could also pour some wax: it will seal it while allowing movement. The same bitumen spray may help.
