My 3D prints shift along the Y-axis on my Ender 3 3D printer. I don't know what to do. My Y-axis belt is tight, So I don't think that is the problem...
Y-axis layer shifting
3 Answers 3
Check for wobble in the X gantry and Y gantry also your Y-axis belt should vibrate like a snare when you pull it and let go. Same goes for your X-axis belt. If that doesn't work see if going back to Cura 4.6 helps (it did for me) and lower your acceleration in Cura (advanced settings movement).
  • $\begingroup$ By definition, what are the gantrys? $\endgroup$
    – X Builder
    Nov 9, 2020 at 23:05
  • $\begingroup$ I'm sorry I mean the hotend plate and the heated bed plate should not wobble so the concentric nuts should be tight but not to tight there are various video's on this. Too tight and the v-wheels will wear down and have to be replaced after a shorter period than normal. Next to that make sure all the screws that hold the frame together are tight if they aren't, it could cause resonance or unnecessary vibration. $\endgroup$
    – Nathan W
    Nov 10, 2020 at 12:19
Another issue might be layer height and extrusion i ran into minor layershifting today but after tuning my Z-offset i now have perfectly straight layers, try calibrating z-steps and e-steps there are plenty off videos on that. It does look like your layer height is pretty high, and lowering the speed (and or accelaration) with which you print can drastically improve your print quality at the cost of time. Please let me know if this worked.
You have a significant hardware problem.
It might be that your belt is slipping, or your motor is skipping, or your rollers need to be adjusted, cleaned, or replaced.
Quality is a bit potato, so it's hard to say exactly what's going on, but it looks like you are also printing way too hot. That may be compensating for wet filament or poor levelling/zeroing, either of which could lead to the nozzle dragging, possibly leading to skipping. I would expect at least the towers and maybe the print to break free if that were the case though, so I suspect it's a separate issue.
