My Prusa Mini arrived with a defective X axis belt. I can order a replacement and it is covered by warranty. But I would also like to know its specifications. This information is available on the store page for the MK3 but not the Mini.
$\begingroup$ You might just ask them... They are pretty responsive to email or questions on their web site. $\endgroup$ – BobT Nov 18 '20 at 15:33
To be sure you could measure the width and the tooth spacing (pitch). The most probable and used belt in 3D printers is the GT2 6 mm belt. The teeth are spaced 2 mm and the width is 6 mm.
