I've never used a 3D printer before. I'm trying to print the calibration cube found on Thingiverse. After the process finished, I noticed that the face pointing up that forms the inset at the base of the letters Y and X was not printed and I could see a hole. The same for the faces pointing down at the top of the letters. At first I thought that it was a printer issue, then I checked the relevant slices and I found out that those faces are not built at all in Cura: enter image description here If I do the same in the Prusa slicer, I get the necessary base: enter image description here
How do I get the same in Cura? How is this setting called?
Cura has several settings that can cause it to erroneously omit small top/bottom surface "skins". Look for preshrink ("Skin Removal Width"), expansion ("Skin Expand Distance"), and particularly the limits on when expansion takes place ("Maximum Skin Angle/Minimum Skin Width for Expansion").
Normally Cura shrinks then expands skins by the same amount, proportional to line width, to avoid generating skin (which is slow to print and harms layer adhesion when mixed with walls) in places where the walls will already cover it. But the recently added max-angle/min-width settings cause the expansion to be skipped in certain places, leaving just the shrinking, and thereby serious gaps in the surface. This feature is just misguided and should be disabled by setting the min width to 0.
If you still have problems after that, you can try lowering both the shrink and expand, possibly even all the way to 0, but this will harm print quality and shouldn't be necessary.
