I have a FLSUN printer: 3D Printer DIY Kit Auto Leveling Cube Full Metal Square Large printing size 260X260X350 with heated Bed Precision.
I plan on using PrusaSlicer as slicer (found it in Ubuntu.)
I now need to pick a Firmware Type in the setup screen. Which one should I select? I vaguely remember it should be RepRap, but I'm not sure.
PrusaSlicer Configuration Wizard
    $\begingroup$ Does the printer not display the firmware name and revision when it powers up? It is probably either Repetier or Marlin. $\endgroup$ – Mick Dec 1 '20 at 17:06
    $\begingroup$ I never turned it on. I guess it is time to do so! I will do this next week... $\endgroup$ – MeSo2 Dec 2 '20 at 5:33
  • $\begingroup$ Most common is RepRap, as most printers use Marlin, which implements the RepRap code Style. $\endgroup$ – Trish Dec 2 '20 at 13:43
