I bought a set of 5 stepper motors from Trianglelab's official Aliexpress shop.
Only one of these motors was given any kind of protective bubble wrap for shipping. The contents of the package shifted in transit and several of the motors got banged up with two of them suffering visible damage to their wire insulation.
I contacted Trianglelabs and was told to fix it myself for \$0.03 with a wire or to add some tape. This repair advice was accompanied with the weightiest assumptions of my personal expertise that I have ever received.
At this point I'm not planning to keep them if this is how the company does business; shaving pennies on shipping and telling the buyer to fix it themselves.
But all of this brought up an interesting question. How can I reliably test my stepper motors for basic functionality and measured compliance with the rated specifications?
  • $\begingroup$ At a minimum, you could check the resistance of the windings for open circuit/short circuit. $\endgroup$ Dec 2, 2020 at 11:08
  • $\begingroup$ Can you share photos? $\endgroup$
    Dec 2, 2020 at 13:41
  • $\begingroup$ Trianglelab is usually a very reliable seller, just like Bigtreetech. I would not exclude them for a single issue. Have you opened an official ticket or have you written them directly? official disputes are REALLY efficient and you usually get the whole sum back. No seller wants to mess with Ali's rating system, considering how difficult is to get into Ali's webshop (I know people who wanted to but did not qualify yet). $\endgroup$
    – FarO
    Dec 3, 2020 at 21:19
  • $\begingroup$ Trianglelab accepted AliExpress's proposal of refunding 1 of the 5 motors yesterday. I had sent a revised offer to refund the two with damaged wires instead of returning the entire order for a refund (my original proposal). Trianglelab countered by pre-emptively closing the case by accepting AliExpress's better proposal. They never respond to any of my messages on their store. Today I found out that sellers (not just buyers) can accept AliExpress's resolution proposals. $\endgroup$
    – Zhro
    Dec 4, 2020 at 16:12
For the AliExpress part, open a dispute and attach pictures to the dispute and ask for a partial, reasonable discount. It always worked for me.
As for how to test the motors themselves, it depends on what other hardware you have.
For example, you could wire the motors to your printer board, and try to issue a G6 command to that motor.
If you find issues while testing the motors, that could be evidence for an even bigger discount, or even full refund if the motor doesn't work.
    $\begingroup$ I would dispute and state "wares came in unusable" $\endgroup$
    Dec 4, 2020 at 16:56
I would be far more worried about damage to the wire insulation (i.e. are they nicked/cut at all or just scuffed up?) as that could potentially lead to a short circuit situation against your frame etc. Assuming no serious cable damage, motors can take a fair amount of mechanical abuse so I'd just put them through their paces with short (a few seconds) forward/backward movements at various speeds listening for any scraping/grinding/other unusual noises indicating any interior damage. Assuming no issues found, then you could run them for a more extended period of time (5-10 minutes or so periodically changing direction/speed) and if that didn't reveal anything, I wouldn't worry about it. If it helps, you're probably going to inadvertently abuse them electrically/thermally far more than the shipment did over their service life.
Unfortunately, when shipping things overseas sometimes the packaging is insufficient (somewhat surprising for Trianglelab as that's one area I generally see people give them high marks for) and bad things can happen during shipment. I've received all sorts of mangled packages and, aside from the irritation of knowing it was probably avoidable but for the bad packaging, I usually try to be reasonable when tallying up any damage when asking for a refund (partial or otherwise). If you really feel like a seller fell short, then your best recourse is generally to ding them on their rating if it's really warranted. Yes, it's irritating, but it will happen from time to time.
