Why do printers, like the Ender 5 Plus, execute the G29 routine prior to every print? I understand the purpose of this step when MANUALLY leveling the bed since you are presented with the 16 measurements and can adjust the four corners of the bed. However, from what I can tell, there is no way any of the printers out there (Creality, and others) to actually level the bed. Since there are only TWO Z-axis motors... one on each SIDE of the bed... then, at most, the only thing the printer COULD do at this stage is to gradually TILT the bed from side to side to adjust the height of the left or right side.
Now, all of that aside, I guess, in theory, it WOULD be possible for the printer to use these 16 measurements to dynamically ADJUST the height DURING THE PRINT based on where the head is SUPPOSED to be versus where the ACTUAL height of that spot actually IS. However, I cannot find anything that claims this is what happens. From everything I find, the G29 routine is run and is done. This means you can only benefit from it during the manual leveling process.
Am I missing something?
