I recently bought an Ender 3 Pro, and while I'm super happy with it, there's one issue I'm having with it.
When I set "Pause at height" to a specific layer in Cura, the print will pause at that height, but as soon as it pauses the nozzle heats right back up and the print continues. It's like it pauses for only 30 seconds.
Here's the G-code for the pause command generated by Cura:
;MESH:NONMESH
G0 F300 X115.454 Y119.213 Z1.96
G0 F9000 X117.5 Y120.392
;TIME_ELAPSED:283.376298
;TYPE:CUSTOM
;added code by post processing
;script: PauseAtHeight.py
;current layer: 6
M83 ; switch to relative E values for any needed retraction
G1 F1500 E-10
G1 F300 Z2.96 ; move up a millimeter to get out of the way
G1 F9000 X190 Y190
G1 F300 Z15 ; too close to bed--move to at least 15mm
M104 S0 ; standby temperature
M117 CHANGE
M0 ; Do the actual pause
M109 S200 ; resume temperature
G1 F1500 E10
G1 F1500 E-10
G1 F300 Z2.96
G1 F9000 X116.604 Y120.251
G1 F300 Z1.96 ; move back down to resume height
G1 F1500 E10
G1 F1200 ; restore extrusion feedrate
M82 ; switch back to absolute E values
G92 E256.16251
;LAYER:6
;TYPE:WALL-INNER
;MESH:Super Curcan.stl
Anyone ever run into this issue?
  • $\begingroup$ I heard in a YouTube video that M0 (the pause command) doesn't work in the Ender 3 Pro firmware. It didn't work for me, either. I guess this confirms a stock firmware Ender 3 ignores the pause command. $\endgroup$
    – Ron Jensen
    Jul 2 at 23:32
I had the same problem (Cura v4.9.1). What fixed it for me was switching to a different Method.
On the screen where you set up the pause, the 3rd dropbox is Method. Set this to BQ (M25). That did the trick for me.
As I understand it, it mimics a pause like what you get with the pause you would execute using the menu on the printer.
