I have an Anycubic Kossel with Trigorilla Motherboard, Mega2560+RAMPS1.4.
I'm using Marlin 2_0_bugfix
My Y connector is not working anymore so I would like to use E1 connector as Y. I found a very good solution here but for me for some reason it's not working.
I did that modification what suggested in the pins_RAMPS.h file (for Y of course instead of X), then I compiled it with Arduino 1.8.13 and uploaded to my printer.
After that I flashed firmware then Y (which I plugged to E1) is not moving anywhere. I have never plugged anything to E1 before, so I think the connector port must be good and working.
What I am missing, what's my mistake?
What I did:
#define Y_STEP_PIN         36
#define Y_DIR_PIN          34
#define Y_ENABLE_PIN       30
#ifndef Y_CS_PIN
  #define Y_CS_PIN         44
#endif
#define E1_STEP_PIN        60
#define E1_DIR_PIN         61
#define E1_ENABLE_PIN      56
#ifndef E1_CS_PIN
  #define E1_CS_PIN        49
#endif
  • $\begingroup$ This should work, I've looked into the pins files for you. Is the stepper driver for E1 working? Is there a stepper driver installed? Just wild guesses. Swap drivers and cables to be sure. $\endgroup$ – 0scar Dec 27 '20 at 21:43
  • $\begingroup$ You were right.I just figured out that the stepper was not working for E1, I will try it with another one. And maybe the Y connector is also good, only the stepper i faulty. Thanks for the idea, I tried a lot of thing without luck $\endgroup$ – Davinho Dec 28 '20 at 22:32
If you followed the answer to switch steppers in firmware to the letter, but changing X for Y, this should work.
I've looked into the pins files for you and concluded that your proposed changes should work.
This leaves you with the following questions:
  • Is the stepper driver for E1 working?
  • Is there a stepper driver installed?
  • Is the cable working/not damaged?
Swap drivers and cables to troubleshoot the problem.
