From day one, I had issues with the bed unleveling all the time even if I hadn’t touched it.
After watching more videos I bought springs and I was having fantastic prints every time. There was no need for levelling between prints - it worked perfectly.
The day before yesterday I got an error warning thermal runaway printer halted please reset so I did as the printer said and again tried the print and 20-30 mins in the exact same issue. I watched more YouTube videos and replaced the motherboard with an SKR E3 V2.0 mini with Marlin firmware installed on to it.
After installing I went ahead and tried to test print (file on provided micro SD card) and 30 mins in I got a thermal E1 so I went ahead and watched more YouTube videos which suggested that I connect my printer to my PC via a USB (provided) and download Pronterface. I followed the instruction of typing M303 V5 200 into the command prompt and sent it to the printer which again halted the printer with E1 error code. I went over to the printer and unplugged the USB and waited while the printer was off before plugged the USB back in.
After doing this I got a TMC CONNECTION ERROR message on the printer. I followed some Reddit/Github posts that said:
Send command M122 to the printer, this should work, which it did not.
As it stands at this moment this printer has gone from working perfectly to nothing at all.
    $\begingroup$ Please clarify your question:. "nothing at all" doesn't sound like "thermal runaway." $\endgroup$ – Perry Webb Jan 7 at 15:03
  • $\begingroup$ It will print 1 or 2 layers then thermal runaway message comes up with a loud beeping noise $\endgroup$ – Mjlawson91 Jan 7 at 15:16
  • $\begingroup$ So you replaced the controller board and experience the same thermal runaway behavior. That implies that the board isn't the cause. You need to check the rest of the hardware. Loose/faulty thermistor or heater cables, fan shifting onto the hotend, etc. $\endgroup$ – 0scar Jan 8 at 12:02
  • $\begingroup$ I have corrected this issue by fully replacing the hot end and wiring (thermistor and heating cartridge) $\endgroup$ – Mjlawson91 Jan 8 at 19:38
  • $\begingroup$ I’m guessing you don’t know then $\endgroup$ – Mjlawson91 Jan 11 at 23:18
