I recently added a Creality BLTouch v3.1 to my Ender 3 which has a MKS Base v 1.6 motherboard and is running Marlin 2.0, but the Z-min never triggers.
I have made sure that the BLTouch unit lights up, uses the provided mount for the Ender 3 to get proper placement and is connected to the Z-min pins. Additionally, I have followed multiple youtube videos for connecting/setting the right parameters for the sensor. However, I haven't found the right combo.
I have tried both BLTouch and Creality BLTouch, different pin number assignments (other than the standard Z-min pin), but the status doesn't change with or without the sensor pushed in. Looking for suggestions on settings to apply, or if anyone has had this issue.
See pictures below:
- Connection to motherboard, tried using the other pin on the z min, and switching the black/white wires to see if they we're connecting wrong.
- BLTouch depressed which lights up as expected.
- BLTouch not illuminated when open.
Marlin still sees it as open
"? Please update the PasteBin files with the latest configuration edits, the first posted are now out of date. $\endgroup$Recv: z_min: open
. If I pull out the sensor on the BLTouch and the light is off, I get the same message from the M119 command. I also tried this on all 4 server pin sets just in case I hadn't put the correct pin in my config, and each time the BLTouch completed the self test as expected. $\endgroup$M119
with a BLTouch? That doesn't make sense to me, furthermore it is the first time I ever heard anybody do that. The documentation already expresses that you cannot do that!The BLTOUCH probe only sends a brief pulse, so “TRIGGERED” indicates the probe is in error state.
So, your status beingopen
is a good thing! $\endgroup$
