I'm struggling with bed adhesion for nylon on a glass bed (122 °C measured) in an enclosed chamber (45 °C near the front, likely more on top of the print bed). I used a glue stick to enhance adhesion, but after around 20 minutes the print comes off the bed.
I tried a no-brand glue stick and a Pritt glue stick.
Now I wonder whether they are suitable for the purpose, because nylon should really be printable in these conditions. Maybe the glue cannot hold those 100+ °C temperatures.
How to find out whether a glue stick is PVA-based and suitable for nylon (or polycarbonate, ABS) printing?
3 Answers 3
Elmer's apparently doesn't reveal its glue stick contents. Elmer's has at least four different glue sticks without giving the difference in composition. You can find glue sticks that specify use for 3D printers. They contain PVP. Many wood glues have PVA. PVA may be labeled also as PVAc, or as "VA/crotonates/vinyl neodecanoate copolymer" (for example in hairsprays).
It looks like you will need to search patents to find contents of glue sticks. Her are examples.
According to Elmer's patent 6268413, Wood Glue Sticks have PVA, but I haven't seen such a thing:
This Elmer's patent has PVA: High-strength adhesive paste and dispenser Patent number: 6268413 Abstract: The present invention includes a high strength adhesive and includes a dispenser containing a high strength adhesive. The invention is an adhesive composition comprising: (a) water present in an amount of from about 40 percent to about 70 percent by weight; (b) polyvinyl acetate present in an amount of about 15 percent to about 35 percent by weight; (c) dextrin present in an amount from about 5 percent to about 35 percent by weight; and (d) starch present in an amount from about 0 percent to about 5 percent by weight; the adhesive having at least 30% by weight solids, having a paste-like consistency, and having a bond strength greater than about 2000 p.s.i. as measured by ASTM D-905. The adhesive of the present invention has a very workable consistency that is very much like room-temperature butter or shortening used in cooking.
Elmer's patent with PVP: HIGH-STRENGTH GLUE STICK FORMULATION, Publication number: 20110301260, includes water; a defoamer; a bactericide; an oil; polyvinylpyrrolidone; a plurality of polyurethane dispersions; dipropylene glycol n-butyl ether; sodium stearate; casein; sodium hydroxide; and at least one adhesion promoter.
Another Elmer's patent has PVP: Adhesive applicator crayon Patent number: 6066689 Abstract: Adhesive compositions exhibiting fast cure time in solid form, e.g. in the form of an applicator crayon or glue stick. The adhesive exhibiting polymer of the composition is based on a mixture of critical amounts of high molecular weight polyvinylpyrrolidone polymer, with a lower molecular weight polyvinylpyrrolidone polymer, with water, an organic solvent, and a salt of a long-claim fatty acid, e.g. sodium stearate. Color indicators and other optional ingredients, e.g. mildewcide, can be included.
Not all glue sticks work! The working ingredient of a glue stick is Polyvinylpyrrolidone; a more elaborate answer is found here on question: "Why does hairspray work as an adhesive for ABS?".
There are very good alternatives to glue sticks and hair spray nowadays. Specific adhesion sprays exist for several years now (e.g. Dimafix, 3DLAC, Magigoo for PA, Plasticz, PrintaFix, Dr.Mat, etc.; my personal experience is with the first 2 mentioned, both work for nylon: Dimafix has more tack at higher temperatures > 80 °C, up to 80 °C 3DLAC works perfect).
E.g. Dimafix has a higher temperature application range than e.g. 3DLAC. From the manufacturer can be seen that:
enter image description here Source: http://www.dima3d.com/en/home/dimafix/
This image shows that the spray has its maximum tack/adhesion at about 120 °C and holds this adhesion level at least up to about 145 °C according to the image.
However, not all glues get stronger with temperature! PVA (also called PVAc) glues soften very quickly, making them good only at low temperature. See "Influence of temperature on the strength of bonded joints" which discloses this graph for PVAc Rhenocoll 3W, 4B Plus:
  • $\begingroup$ I think I tested the glue stick at too high temperature (120°C), but anyway yesterday I tried also a hairspray with PVA at 60°C bed temp. and it didn't work for thin areas of a printed part with 3 mm brim. I may try again with 10 mm brim! and with wood glue. But I ordered Dimafix as well. I should have recorded a video... $\endgroup$
    – FarO
    Commented Jan 13, 2021 at 9:43
  • $\begingroup$ @FarO A department of the company I work for uses Dimafix for all their prints (I print other materials at lower bed temps, so it has never been my favorite, 3DLAC has better adhesion in the 60-70 °C range according to my experience). Note that also specifically engineered sprays exist for PA (nylon), you could also try Magigoo for PA. I have no affiliation whatsoever! Just sharing my experiences. $\endgroup$
    Commented Jan 13, 2021 at 13:28
Not all Glues are PVA based. There is one glue manufacturer call CGMaxed that makes an alcohol based PVB glue. Sold on Ebay exclusively for 22 dollars per 6 oz. I use it every day when my supports fail to stick or having levelling issues.
