I am working on refining my PMMA printing process and I am trying to print as close as possible to the theoretical 100 % density of the material. I am making good progress and am slowing increasing the extrusion multipliers to try and find a good set of print settings.
I recently have run into an issue where the bottom ≈1/3 of the test cylinder is coming out rather distorted (see picture). The problem seems to sort itself out as the finish around the top of the cylinder looks fine. Do any of you have any experience with PMMA or have seen this problem before?
My initial thought is that it is heat driven and as more material is added it becomes less of an issue as there is more mass to dissipate the heat. For reference I am printing on an Raise3D Pro2Plus, for my prints I am running the extruder at 250 °C and the heated bed at 100 °C. I am eventually going to need to print rather large cylinders and would like an even surface finish along the length of it.
Test Cylinders, right and left show distortion on the bottom and the center shows a bizarre print where half of the cylinder was fine and half came out very jagged.
