The printer does not retract the filament for some travel moves result in scrape printing part as shown in picture.
This is my printer setting. Not sure which part be the problem.
I want my printer to retract the filament as I have set it to. Where to check and what could be the problem?
  • $\begingroup$ What is meant by "result in scrape printing part"? $\endgroup$
    Jan 15 '21 at 13:42
  • $\begingroup$ The nozzle do rapid move and hit under layer. Sometimes the build plate shifted or the part popped out from bed. $\endgroup$
    – M lab
    Jan 15 '21 at 16:23
Minimum Travel after Retraction is exactly what it says on the tin: if the travel after a retraction would be less than 2 mm, it does not retract. You'll want that to be short, but not 0, because retraction can lead to under extrusion at the start of a new line, and every swap from one shell to the next shell right next to it is classed as travel.
  • $\begingroup$ I think so but you see somw travwl got very long distant but it still not retract which so confusing. $\endgroup$
    – M lab
    Jan 16 '21 at 0:48
  • $\begingroup$ Set it to line width and see what happens? $\endgroup$
    Jan 16 '21 at 9:47
  • $\begingroup$ 0.4 or slightly over should work fine. $\endgroup$ Jan 17 '21 at 5:25
  • $\begingroup$ Retraction does not cause underextrusion though; rather it's necessary to prevent it. $\endgroup$ Jan 17 '21 at 5:26
  • $\begingroup$ Okay then any way to make 3d printer just lift the nozzle up with no retraction? $\endgroup$
    – M lab
    Jan 18 '21 at 13:48
