I installed a BLTouch probe on my Ender 3 V2 and am able to manually generate the probe matrix and store it in the printer memory, but I can't figure out how to get Cura to run the probe for every print. I have included G29
in my start code, but the printer doesn't run the probe. Here is my full start code:
M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
M220 S100 ;Reset Feedrate
M221 S100 ;Reset Flowrate
G28 ;Home
G92 E0 ;Reset Extruder
G29 ;BLTouch
G1 Z2.0 F3000 ;Move Z Axis up
G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
When I inspect the G-code directly, I can see that G29
is getting transpiled into
M501 ;load bed level data
M420 S1 ;enable bed leveling
is this correct? If not, how do I stop the transpilation?
