Printer: Ender 3 Bed: Creality Glass ABL: BLTouch Everything else: Stock
Few weeks ago I had a meltdown during a failed ABS print. My hotend was completely wrapped in plastic and trying to remove said plastic I snagged the termistor. Anyway I had to replace the nozzle, hotend and thermistor. Everything on here. I went ahead and measured the Nozzle BLTouch needle offsets and re-flashed my Ender 3 with TH3D Firmware and configured BLTouch. After which I adjusted the Z offset again.
All good here. BLTouch appears to work, well at least it appears so.
I started printing and I see that my bed always hangs lower on the right side and BLTouch does not compensate for this difference.
Manual leveling (with a heated bed, also tried without)
- Auto home
- Move Z axis from 5 to 0
- Move the head to each corner of the bed
- Adjust the corner hight using the paper method (repeat 2x for each corner)
- Auto home
- Go to Z offset, and move it until it tugs on the paper.
- Save and Auto home
But this did not solve the issue. When I move the head to Z0 (with the offset) in the centre it's perfect. Moving it to left gets close to the board, right goes way away from the board.
Belts & screws
Went and tightened all the belts and all the screws.
X Axis alignment
I set the Z axis to the max 250. And measure the distance from top of the X axis to top of the frame. There is no difference in the left, right or centre of x axis to the top of the printer. Same for distance from bottom part of the frame.
I cleaned the belts and the wheels with a soft brush. Not sure what else to do. I'm giving up on Creality/Ender :(
