Got a tricky problem here : I print plate (76x70x3 mm) however there heights (Z-axis) are not correct every time...
My extruder has been re-calibrated. My bed has been re-calibrated.
So Firstly I re-calibrate X, Y, and Z-axis with this cube (thingiverse) :
Here is a picture before and after calibration You can see the cube is perfectly equal
However, my problem persists. Whatever the plate I want to print, the height is always incorrect. And not only with these pieces with all other plates I created. All other axes than Z are correct.
It's important to note that Cura always sees the correct size :
I really don't understand why only on the plate my height is not correct but for the larger piece, it's correct.
I really want an explanation, thank's a lot !!
