I own a Magic Build 3D Printer. I found out, that the glass is scratched like in the picture.
So, I'm looking for a replacement glass plane to put in front of the projector. Is this a special glass? What are the properties? Where can I find it?
This is a sheet of glass you'd most likely need to acquire as a replacement part for your printer's manufacturer:
  • The dimensions of the glass, especially with the rounded corners, are usually very odd and make buying a spare from a glassmaker really expensive.
  • Some printers like the Elegoo Mars have an LCD mounted as part of this sheet.
  • Printers also might have this plate coated for different properties, for example, to reduce reflectivity and refraction inside the printer.
In this case, we have a DLP setup that uses a projector. You best inquire at the manufacturer itself using their website, E-Mail or facebook about a few spare pieces - that will get you the same quality as the bed you already had (save for the scratches) and they usually have such items in stock.
