I want to access the bed and nozzle temperature sensor data of a 3D printer via serial connection. Could someone please guide me in the right direction?
Thanks!
Edit: Response from printer:
Connecting to printer...
Connection response from printer:
6R7�P)��h>L�JO� � ��V�\��`�r��T �� SK�<ʪ� �>�Vw^$���|���R n�I, o�!����H>�
mx�}M#
�LYԣPh���^@ ��rp � TP�j�~1�� V6 6 � f� 6�k#���&�H".��k K2���ek�(��&��^K�k2����Ul�(� ���~N�ʈ*.�>Z��k#d$�����(� ��
��(� ��� v��
Asking for temperatures (M105)...
Temperature response from printer:
^CTraceback (most recent call last):
File "printer_files/serialaccess.py", line 15, in <module>
response = ser_printer.readline()
File "/usr/lib/python2.7/dist-packages/serial/serialposix.py", line 446, in read
ready,_,_ = select.select([self.fd],[],[], self._timeout)
KeyboardInterrupt
After the code asks the printer for temperature values, there is no output on the terminal anymore. I waited for a while and then killed it using control+c. It is clear that the printer is responding to the connection response but I am not sure why it is not returning the temperature values. Again, thanks a lot for your help, Demetris!
