I'm setting up a replacement Melzi 2.0 board from TRONXY for my i3 clone (a Monoprice Maker Select v2 for those curious), which according to the RepRap wiki has A4982 drivers for all the steppers. I'm attempting to configure Marlin 2.0.x for this printer and this is the last big problem I'm encountering.
The problem: The Z-axis (or any motors connected to the Z-axis driver) won't budge no matter what I try. All my other steppers work fine.
What I've tried: I've done everything I can to prompt the Z-axis to move, from Gcode commands to homing via the LCD and Pronterface. I've connected my X-axis motor to the Z-axis driver and it won't move either. Sometimes, when I send a command for them to move, they'll make a small noise - like they're getting power - but won't move. I probed the motor connectors at the board and received nothing but a few stray millivolts here and there, very different from the several volts on my Y-axis motor when I did the same thing. Bear in mind, that was just one test moving them from the LCD, and this time they did not make any noise or attempt to move. I have switched pin definitions in the firmware for X/Z ENABLE/STEP/DIR and the Z driver once again appeared to be the culprit, keeping the Z-axis planted even if it was being controlled as if it were the X-axis.
What I think the problem could be: To me, this seems like a software problem. I'm configuring Marlin for my first time and I think I messed something up somewhere. Could it be a problem with the trim pots, motor currents, motor enabling, or something else? Outside of that, maybe the driver is just dead?
My Marlin 2.0.x config.h for reference:
// These are all excerpts from various parts of Configuration.h
#define DEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, 400, 500 }
#define DEFAULT_MAX_FEEDRATE { 300, 300, 4, 25 }
#define DEFAULT_MAX_ACCELERATION { 3000, 3000, 100, 10000 }
#define DEFAULT_ACCELERATION 2800 // X, Y, Z and E acceleration for printing moves
#define DEFAULT_RETRACT_ACCELERATION 2800 // E acceleration for retracts
#define DEFAULT_TRAVEL_ACCELERATION 2800 // X, Y, Z acceleration for travel (non printing) moves
//#define CLASSIC_JERK //left at default
// :{ 0:'Low', 1:'High' }
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define E_ENABLE_ON 0 // For all extruders
#define DISABLE_X false
#define DISABLE_Y false
#define DISABLE_Z false
#define INVERT_X_DIR false
#define INVERT_Y_DIR false
#define INVERT_Z_DIR false
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define X_MAX_POS X_BED_SIZE
#define Y_MAX_POS Y_BED_SIZE
#define Z_MAX_POS 150
#define MIN_SOFTWARE_ENDSTOPS
#if ENABLED(MIN_SOFTWARE_ENDSTOPS)
#define MIN_SOFTWARE_ENDSTOP_X
#define MIN_SOFTWARE_ENDSTOP_Y
//#define MIN_SOFTWARE_ENDSTOP_Z //disabled until the driver works correctly
#endif
#define MAX_SOFTWARE_ENDSTOPS
#if ENABLED(MAX_SOFTWARE_ENDSTOPS)
#define MAX_SOFTWARE_ENDSTOP_X
#define MAX_SOFTWARE_ENDSTOP_Y
//#define MAX_SOFTWARE_ENDSTOP_Z
#endif
//#define Z_SAFE_HOMING
#if ENABLED(Z_SAFE_HOMING)
#define Z_SAFE_HOMING_X_POINT X_CENTER // X point for Z homing
#define Z_SAFE_HOMING_Y_POINT Y_CENTER // Y point for Z homing
#endif
// Homing speeds (mm/min)
#define HOMING_FEEDRATE_XY (50*50) //changed from 3000 to 2500
#define HOMING_FEEDRATE_Z (4*60)
// Validate that endstops are triggered on homing moves
#define VALIDATE_HOMING_ENDSTOPS
// Sorry if that was a bit much, I tried to include all the settings that could
// potentially have an effect on the Z motion.
I genuinely have no idea where to even look to solve this problem, so any guidance or advice would be hugely appreciated!! Thanks!
My conclusion is that the driver chip itself is dead and replacing it ought to fix the problem. If this works, I will post an answer to this question.
ENABLE
,DIR
,STEP
) of Z and e.g. Y in firmware configuration for a while, and try to manually move (LCD or G-code) the Y and Z axes a bit ? (Better swap also endstops if you are going to home, etc.). Then you will know much better if this is really a software problem. $\endgroup$ – octopus8 Feb 6 at 23:40
