Has anyone successfully replaced the inductive Z probe on the Monoprice MP10 (Mini or regular) with a different type, such as BLTouch or IR? I find that the stock inductive probe isn't so accurate, and since it's inductive it only works with the aluminum build plate but not with glass or PEI, which I much prefer.
From Thingiverse you can find a BLTouch mount for the MP10 (and MP10 mini):
MonoPrice MP10 BLTouch mount
Note that in order to use the BLTouch sensor you need a different controller board that supports connecting a BLTouch sensor as the MonoPrice controller board doesn't support connecting a BLTouch sensor.
From ref.:
A BLTouch adapter for the Monoprice MP10 & MP10 Mini. NOTE: you will need an open source control board to get this to work as the stock firmware on the MP10 line of products does not allow for a BLTouch.
  • $\begingroup$ What control board did you use? $\endgroup$
    – SZH
    Feb 15, 2021 at 16:51
  • $\begingroup$ @SZH I don't own a MP10, but there are plenty of boards out there nowadays, you are doing good by investing in a 32-bit controller board with enough drivers and options. $\endgroup$
    Feb 15, 2021 at 22:58
