Klipper lets you define a skew profile that is loaded / unloaded on demand during START_PRINT / END_PRINT macros called during printing of a sliced file. This seems to be the recommended way to apply the skew in Klipper, in fact it is in the documentation this way: https://www.klipper3d.org/skew_correction.html.
My question is, should I also manually load the skew profile prior to executing the BED_SCREWS_ADJUST built-in command in Klipper?
Or does BED_SCREWS_ADJUST ignore the skew entirely so it doesn't matter?
    $\begingroup$ This is not dependant on the printer, it's Klipper/Firmware. $\endgroup$
    Feb 18 at 12:59
  • $\begingroup$ My question is about Klipper, it is true. :) $\endgroup$
    – Sam T
    Feb 18 at 16:10
The skew correction works in X/Y axis while bed screws helps you correct the ax axis. Since they don’t work in the same axis, I don’t see why they would interfere with each other.
  • $\begingroup$ Welcome and thank you for your contribution. When you get a chance, please take the Tour to understand how the site works and how it is different than others. $\endgroup$
    – agarza
    Mar 8 at 14:18
  • $\begingroup$ @victor-lazaro But skew correction I am doing has XY, XZ, YZ component - thingiverse.com/thing:2972743. I thought this meant Z coordinate is adjusted, similar to a mesh. But I could be wrong! Still a bit unclear about it. $\endgroup$
    – Sam T
    Mar 9 at 16:47
    $\begingroup$ You’re right. My bad. I don’t use skew correction on mine, I just fixed the frame. $\endgroup$ Mar 9 at 16:48
  • $\begingroup$ After some months with the printer, I think I agree that squaring the frame of my little cartesian printer is simple enough to avoid skew correction in software as well. $\endgroup$
    – Sam T
    May 20 at 14:43
