I noticed that when printing small teeth on a pulley that the angle is not matching the design angle. I am printing without any support structure.
Overview:
overview
Detail:
Detail in question
Printed:
The printed overhang incline angle under the tooth looks good (maybe not quite steep enough;) but the top angle of the reclining section looks too flat. It is as if the tooth is too perky.
(I have observed a similar behavior when printing overhanging corners. They build upward more quickly.)
What is causing this, and how to prevent it?
I reduced the speed for the outer layer to 30 mm/s, the infill is set to 40 mm/s. Layer (Z) is set to 0.1 mm. Material PLA 1.75 mm, nozzle 0.4 mm.
Cura layer detail:
Cura detail
Cura Prepare
Cura prepare
Cura Preview
close up
I think the issue is unsupported overhangs. There is not enough material to support the first layer of each small tooth. Have a look at how your slicer slices the first couple layers at the bottom. It might be that it tries to reduce the angle to 45°, so that it can print overhangs, or the overhangs are drooping before the next layer can assist with support.
Looking at your first two images, I think the printed top part of the tooth is actually quite similar to your 3D design.
You can fix this by making the tooth profile from the side have a 45° slope to maximum height, and the same on the top if you want the teeth to appear symmetrical.
    $\begingroup$ I would like to have it symmetrical, and was considering adjusting my design to be asymmetrical so it would print more symmetrically. I added two side view (last 2 images) of Cura's Prepare and Cura's Preview. It looks like Cura accepted my angle just barely. $\endgroup$ – MeSo2 Feb 20 at 16:45
