I'm getting close with this print, but I'm seeing some rippling at the base that I can't seem to eliminate (see photo at the end of the post). The model is here if it helps. It seems that the texture evens out above the floor of the box.
I think these are the relevant settings:
  • Extruder temp: 240 °C
  • Bed temp: 110 °C
  • Infill outline overlap: 20 %
  • Infill: 40 %, triangles
  • Layer height: 0.1 mm
  • First layer height and width: 200 %
  • Speed: 40.0 mm/s (first layer: 40 %)
  • Bottom solid layers: 3
  • Top solid layers: 6 (I was getting a lot of pillowing with any less; still am even with 6)
  • Perimeter layers: 6
  • Retraction: 1 mm
  • Retraction speed: 20 mm/s
The printer is a Flashforge Creator Pro.
print with unwanted texture at base
    $\begingroup$ Perhaps this answers your question? $\endgroup$ – 0scar Feb 24 at 10:27
    $\begingroup$ Elephant foot. That's an Elephant foot. $\endgroup$ – Trish Feb 24 at 11:02
  • $\begingroup$ Interesting. I've seen elephant foot before but not with this kind of texture. So it's probably a combination of first layer width and my Z stop / bed level? The only thing I'd note is that, while I can't confirm it, it seems like the texture doesn't show up until later in the build. Is that from the extruder pushing down too hard on the print? Anyway, thanks. I'll give it a try tonight. $\endgroup$ – JStroop Feb 24 at 14:28
    $\begingroup$ It used to happen to me when the Z probe distance was not calibrated properly (too close or too far, cannot remember which one). When I calibrated it it went away. However, the cause of your problems might be different. $\endgroup$ – MStarha Feb 24 at 18:44
  • $\begingroup$ That was it! Re-leveled the bed with a business card rather than a sheet of printer paper, and then reduced the first layer width to 125% and all good. $\endgroup$ – JStroop Feb 25 at 17:52
