I can't get anything from my printer since I change filament (I always use PLA from SUNLU). I changed the nozzle, redo the leveling... Every time now, the nozzle seems way to close to the bed and the PLA just stick to the nozzle and not the bed. I was wandering if I need to change the hot end.
This is me leveling each corner and center of the printer using a flyer from a shoe store.Leveling the printer
and this is the result when I try to print stuff (actually square to refine the leveling): Actually printing
    $\begingroup$ How do you level your bed? can you provide a photo? Do you have an endstop on the rails or some sort of mesh-bed-leveling sensor? $\endgroup$ – Trish Feb 27 at 16:53
  • $\begingroup$ Usually I do a manual leveling then I print square in each corner for refining. Unfortunately I can't perform the later because I can't print anything, $\endgroup$ – Benji_90210 Feb 27 at 22:23
    $\begingroup$ please share a photo of your setup. What do you use to determine the distance to the bed? $\endgroup$ – Trish Feb 27 at 23:19
    $\begingroup$ please don't open a new question but edit your questions in the future. $\endgroup$ – Trish Feb 28 at 19:33
    $\begingroup$ @Benji_90210 You cannot add images in a comment, and you shouldn't add info into the comments, you just need to update the question by edit. This isn't a forum, people ask for additional information in the comments, the question poster edits the question with requested information. Thanks for more info being edited in by Trish, but I'm afraid this is still not enough to diagnose the problem. If you think it is too close, add a G-code line to raise the nozzle in your G-code file. $\endgroup$ – 0scar Feb 28 at 21:18
