I recently installed a BLTouch V3.1 sensor on my CR-10S pro. I used the "Tiny Machines" latest firmware.
When I turn on the printer the BLTouch self tests and turns red. When I go to "Auto Leveling" it tries to do homing and the BLTouch retracts a couple times then finally the pin pushes down and stays that way and lights up blue. From there homing stops; it seems and the Z-axis stays high up without trying to touch the bed while the BLTouch light stays blue and pin down. Every time I go back and forth between that screen the same thing happens. I've gone all the way back to an inductive capacitor and the printer still works how it should. Is the BLTouch bad?
  • $\begingroup$ Unfortunately, up to now, no answers are given on your question! Have you found an answer yourself? If so, you may add your own solution and accept that after 48 hours. If you have not been able to address the problem please update your question so other people may help you find an answer. You can even decide to delete the question. We need to reduce the unanswered questions list to graduate from the Beta stage. $\endgroup$ – 0scar Jun 21 at 8:52
