This one is turning out to be a real head-scratcher. I'm running a stock Creality CR-10S and there seems to be a single line approx 45° across the print on the X-axis direction.
I have attached images to better explain. Any help would be greatly appreciated.
enter image description here enter image description here enter image description here enter image description here enter image description here
    $\begingroup$ This are probably wrong theories, so let's exclude them: Does this anyhow correlate with an infill pattern (here I think of "Infill overlap (%)" setting) or with the starting point of print for the outer wall (a Z-seam, you would need to observe during the print)? $\endgroup$ – octopus8 Mar 8 at 19:19
  • $\begingroup$ Do you print Infill before walls? Can you print a copy of that item and abort that print mid-way, showing the infill together with the erroneous area? On the black item, the seams are on the upper or lower edge afaict. $\endgroup$ – Trish Mar 8 at 19:43
  • $\begingroup$ Hi, thanks a lot for the reply. These parts are hollow, and infill for both are concentric. Does it have to do with belt tension or motor vibrations? $\endgroup$ – Anirudh Vasudevan Mar 9 at 2:53
In your slicer check your z-seam overlap. Lines like that are what happens when a slicer is systematically trying to hide a seam while not adding a ton of time onto the print by adding in a bunch of additional time for travel.
  • $\begingroup$ This seemed to be the case, I was using matterhacker for slice and print. Didn't have this issue with Cura. Thanks a lot mate! $\endgroup$ – Anirudh Vasudevan Mar 19 at 0:41
