I'm still fairly new to 3D printing; got my Ender 3 V2 for Christmas last year. Recently the tension arm in the stock extruder snapped, so I bought and installed an all-aluminum replacement. My first successful(ish) print since installing it lasted two to three hours before I noticed the filament wasn't feeding. It had softened and clogged the lead-in to the Bowden tube just past the tooth gear. I figure the problem comes from (and what probably broke the original plastic) heat buildup; the new aluminum frame was VERY hot to the touch. I also noticed that the extruder motor was rather hot as well.
So you all know where I am: all I've printed with is PLA at 195 °C. Since changing extruders, I was getting over extrusion and dropped it to 185 °C and increased the retraction from 5 mm to 6.5 mm. The new one doesn't have (easily) adjustable tension, but the tension felt as strong as I had it on my old one, so I left it alone. I currently print within an enclosure, one of Creality's foil-lined ones since my printer is located in the garage (this is more for dust, but for longer prints I felt it was good to have since at the time it was getting very cold at night in the garage).
I don't think it's heat creep, since that meant it went all the way up the Bowden tube. My first guess is the ambient heat inside the enclosure. I am currently trying a new print with the top and side openings folded up to allow airflow. But I welcome more experienced suggestions and input.
