- Printer: Anycubic Mega S.
- Mods: BLTouch, Dual material with G-code-powered switch.
- Firmware: Marlin 2.0
A couple of weeks ago I had a print failure when printing PETG. Now whenever I use auto bed leveling, it doesn't compensate correctly. The nozzles will be too high on the left side of the bed, and too low toward the right. I checked my firmware configuration, and everything appears to be OK. I also suspect that the failed print may have knocked the Z endstops out of alignment.
I recalibrated the Z-offset on the BLTouch and ran a probe repeatability test. Everything came out fine. My Configuration.h
can be found here. As well as a picture of the hotend setup below.
Edit: I tried leveling the bed manually before using ABL. Still had the same problem.
Edit 2: I looked more closely at the bed leveling logs and noticed that it is reading the bed level incorrectly, contrary to my previous tests. I do not know what this means, but I suspect it has to do with misaligned endstops. Could this be correct?
