So I have been having an ongoing problem with my printer that I just can't solve. I don't usually ask the questions on stack exchanges until my problem gets unsolvable. Unfortunately like this one
Printer: Creality Ender 3 V2
Current Board: Creality v4.2.7 (Silent Motor)
Background: This started when I accidentally fried the T20 chip on the v4.2.2 mainboard when I tried to install the BLTouch incorrectly (I looked at the photo upside down) and and also accidentally pulled the wire out and what I guess is why the T20 chip was fried. I thought at first the PSU was the one causing the trouble at first so I replaced it. Then found the burnt chip and decided to upgrade the board to a v4.2.7. I installed everything correctly according to a video that I found somewhere on YouTube.
Current Problem(s): When I turn on the machine the light on the mainboard is on but there is continuous beeping coming from the display with small clicks like a clock every 1 sec. or so. The backlight to the display is on but nothing is shown. I just found with a multimeter that the bed and nozzle terminals give no volts back.
Firmware: I have tried to update the firmware to the official one off of Creality's website and also using the source code for Marlin v2.0.7.2 with PlatformIO. The tutorial I followed was here:
Update [3/24]: Found that the firmware seems to not flash even after giving the .bin file a different name.
Extra Thoughts: I currently have no idea what to do. I think I might replace the LCD and its cable. I have only printed a few things and just want to get back to it but I don't want to buy a whole new printer to do so. I feel like I get closer to getting back to it every time I fix something but I'm starting to lose hope that it's just a never ending problem loop. I appreciate any help given.
12
  • $\begingroup$ v 4.2.7 of what? is that a creatlity boars? What video did you watch? It reeks of mis-configured firmware. $\endgroup$
    Mar 22, 2021 at 9:48
  • $\begingroup$ Yeah, it's the creality board v4.2.7(silent motor) amazon.com/dp/B07TFTVTXK/…. And there are a lot of tutorials but I think the one that I watched was youtu.be/y87P7K5DTMU cause it was pretty simple. I did no major changes to the marlin firmware except change the bed sizing and environment. $\endgroup$
    – Casheridan
    Mar 22, 2021 at 16:44
  • $\begingroup$ Also it was doing the same problem even without the firmware change. I tried it straight out of the box and got this problem then tried flashing the firmware but still got the same problems. $\endgroup$
    – Casheridan
    Mar 22, 2021 at 16:47
  • $\begingroup$ When you say you tried to compile your own Marlin firmware, which files did you pull for your configuration settings? Did the firmware successfully compile? $\endgroup$
    – Rykara
    Mar 22, 2021 at 18:18
    $\begingroup$ Could be a bad or incorrectly formatted SD card. I think the card needs to be FAT32 format. Try reformating and/or using a different SD card? $\endgroup$
    – Rykara
    Mar 25, 2021 at 1:09
Thanks to the comment from @Rykara, they led me to the answer:
The whole problem was kinda a firmware issue but on the SD card side. The reason why it wasn't flashing was because I didn't flash the SD card to use the FAT32 format. Unfortunately I tried every other format option except that one before hand, mostly because I am mainly on a Mac. Now there is no more problems and I am back on track to printing. :)
I had the constant beeping, black screen issue.
I went to Creality Cloud Firmware for 3D Printers: Ender 3 v2 Mainboard version 4.2.2.
I installed Ender-3 V2-Marlin-2.0.1 - V1.2.1 - Filament because I have the Ender 3 v2 4.2.2 board. This is the only firmware that loaded. I then reran all the other compatible firmware and it loaded them fine. But it only fixed itself once I ran the one with - Filament. No idea why!?!?! I spent hours and this is what did it.
The site's root is Creality Cloud: Download Creality Firmware and Software.
  • $\begingroup$ Nice answer, and hopefully it will be useful to someone else. However, while the symptoms were similar, it seems that the underlying cause is probably different from that of the OP's, which, in their case, was the SD format needing to be FAT32. $\endgroup$
    May 10 at 8:36
