Recently I bought a printer and failed to find Cura 4.8 settings for it (both in application both myself). My printer Zonestar Z6FB
Currently I doubt in:
  1. G-code flavor
  2. All printhead settings excluding extruder number (which is obviously 1 in my case)
  3. Start/End G-code
Add printer image to eye trap someone who also interested
  • $\begingroup$ Your printer looks like a clone of the Creality Ender 2. Have you tried using a printer definition for the Ender 2? $\endgroup$
    – Mick
    Apr 2, 2021 at 12:01
  • $\begingroup$ @Mick believe me it is not a clone. It is the cheapest device you can imagine. $\endgroup$ Apr 2, 2021 at 12:03
  • $\begingroup$ Well... it is very similar to the Ender 2, and also the Tronxy X2. Both are cantilever printers. I have a Tronxy X1 -- also a cantilever printer but no heated bed. I suspect that settings for either the Ender 2 or the Tronxy X2 will also work with Zonestar Z6. Of the two printers, Cura is more likely to have definitions for the Ender 2. $\endgroup$
    – Mick
    Apr 2, 2021 at 12:11
  • $\begingroup$ I've just checked. Cura does have a definition for the Ender 2. $\endgroup$
    – Mick
    Apr 2, 2021 at 12:17
After some pain, I figured out that if you are a poor Ubuntu/Linux user you should only use the AppImage version of Cura which you can download from official website
Next, make the file you downloaded executable chmod +x *.AppImage
Next, start it from terminal or by clicking in navigator
Ok, proceed as is and then HelpShow Configuration Folder.
It will show 2 folders we need ~/.local/share/cura/4.8
Ok now download ZONESTAR_Cura_Resources.zip from here.
Then copy all files from ZONESTAR_Cura_Resources TO ~/.local/share/cura/4.8 but remember that directory structure is messed up but can be figured out.
