I am printing fairly cheap, but highly rated, PLA and not sure whether this is underextrusion or overextrusion; but it just looks bumpy and not clean. My settings:
- 195 °C at 60 mm/s bed temp 50 °C
- 0.4 mm nozzle at 90 % extrusion
- 0.1 mm layer height
- 6 mm retraction at 60 mm/s with 0.50 mm coasting
I tried at 190 °C and it severely underextruded halfway through, but the outside looks much smoother; I also tried with and without coasting with no difference and tried adding -0.2 mm extra restart distance which didn't change much either. Could this be because I am just printing a rather small part (25 mm diameter)? I think this because I tried printing a much larger 100 mm diameter hemisphere just before, which printed perfectly using the exact same filament.
I've switched out to a new 0.4 mm nozzle, tried a 0.6 mm nozzle, but the only complete print I got had this rough and bumpy outside. It is printed in the orientation shown as removing support from those thin legs lead to them snapping.
I also had moderate stringing throughout, which I thought coasting and restart distance would fix.
Any ideas would be much appreciated.
Edit 12/04:
I have since reinstalled one of my all metal hotends, as I wasn't using them due to clogging issues, installed a brand new 0.4 mm nozzle, set the extrusion multiplier to 1.0 and disabled coasting. I also calibrated my e-steps, which means I needed to buy an arduino and burn new firmware.
Sadly I didn't print in between fixed, but these are the results I got.
The prints are much better but there is some pretty serious stringing and zits due to me needing to reduce the retraction distance for the hotend to 2 mm, as the 6 mm distance I was using before would make it clog; but since I'm using a bowden extruder it creates stringing. How could I go about fixing this? I feel like I'm playing a game of whack-a-mole.
