There are a few hits on my issue title but could not find an actual answer/advice. I burned my Ender 3 Pro Creality motherboard and replaced it with an SKR 1.4 + TMC 2209 + BLTouch. Everything is moving like it should and calibrated.
However, at the end of the homing process, the Z-axis goes up, then it's supposed to move to the printing position. At that point, the acceleration is so great that the Z-axis barely goes down and I end up printing about 4 cm above the bed.
These are the settings I changed on my Marlin 2.0.7 firmware in relation to the Ender 3 setup:
Configuration.h
set #define STRING_CONFIG_H_AUTHOR "Nicolas Rietsch v 0.1.2"
enable #define CUSTOM_MACHINE_NAME
set #define CUSTOM_MACHINE_NAME "Ender-3 PRO"
set #define TEMP_SENSOR_BED 1
set #define DEFAULT_MAX_FEEDRATE          { 500, 500, 5, 45 }
set #define DEFAULT_MAX_ACCELERATION      { 450, 450, 100, 10000 }
set #default DEFAULT_ACCELERATION          450
set #define DEFAULT_TRAVEL_ACCELERATION   500
set #define INVERT_X_DIR true
set #define INVERT_E0_DIR true
set #define X_MIN_POS -26
set #define X_BED_SIZE 230
set #define Y_BED_SIZE 230
set #define Z_MAX_POS 250
enable #define NOZZLE_PARK_FEATURE
Configuration_adv.h
set #define X_CURRENT       500
set #define Y_CURRENT       500
set #define Z_CURRENT       500
set #define E0_CURRENT      650
set #define CHOPPER_TIMING CHOPPER_DEFAULT_24V
What am I missing?
  • $\begingroup$ DEFAULT_MAX_ACCELERATION... what is your current value for Z in EEPROM? Have you checked acceleration settings using LCD or g-code? Or reset to defaults? $\endgroup$
    – octopus8
    Apr 28 at 17:05
Maybe it would it help if you fix #default to #define in the current line:
set #default DEFAULT_ACCELERATION ...
