I'm running into an issue with my BLTouch where it will go through the process of leveling when the print has started but will fail at different points each time then immediately go to start printing. Auto homing has worked fine each time, seems to only be happening when starting a print. If it fails on the close left hand side the probe will stay pushed out before it attempts to start the print causing the probe to get pulled a bit. I only ever seem to get 1 successful print before everything seems to break down.
I'm using the firmware from the Creality website
  • $\begingroup$ I've had similar experiences caused by the cables (bad connection), please check the connectors. $\endgroup$ – 0scar Apr 29 at 8:40
