When I first got my 3D printer (a FlashForge Adventurer 3), it came with a sample pack of filament. With this filament, I was able to use skirts for my first layer. When the sample filament ran out, I switched to Hatchbox PLA filament. For some reason, I cannot use skirts with the Hatchbox filament. Now, whenever I try to print something with a skirt, the print moves around, ruining it. The only first-layer that works now are rafts, which I do not like, as they use up more filament and are more of a pain to remove. Is anyone else having this problem? If so, what are some workarounds to this issue?
Here are the failed prints. I terminated them mid-way, as they started to shift on the build plate.
