This issue just started recently; I am not sure if it is because of the specific part I am printing or whether something on the printer is going bad. Up until now, I have been printing all kinds of parts with no problems whatsoever.
I am printing a hollow sphere whose walls have fill paths that require the X and Y to change rapidly. i.e. the wall is 2 mm thick and the wall-line-count setting is set to 2.
When the print head is jerking back and forth to fill in this area it causes horrible vibrations and really bad Y layer shift. You can see the vibrations transferred through the flexible neck of the black LED light in the foreground.
All the Cura settings are at default- I have not tried to speed up my printing in any way by adjusting the settings.
The vibration seems to be coming from the Y stepper.
I have already tried tightening the belt; everything else seems tight.
It is an Ender 3 Pro with a stock mainboard and probably around 50 hours on it +/- 20 hours.
I have printed the same part on my other printer with no issues.
This is happening now on other parts that do not have particularly high jerk paths, it is shifting the Y by a full mm or more at a time.
Would you say the stepper motor is going bad? Or the driver? Or something else?
Here is the part in the video; I of course stopped the print after it started shifting:
And this is how it is supposed to look:
EDIT:
Here is the path that causes the problem:
